Hi!
Could somebody share .bin file of his TCP202 eeprom? By mistake i blanked it during opamp repair (esd?) and my TDS3024B can't identify now that i'm connecting current probe. Chip is ST 24C02W6.
Thank you in advance!
Register from 3.01. one more time with me ... I can do this for you ...
This is my 24c02 dump. You will have my TCP202's serial number. I don't know if you can change the sn with yours, maybe there is a checksum involved that I don't know where it is.
Lovely! Thanks a lot - your dump worked perfectly. Tektronix probes has a B at the beginning and 6 digits later in SN, this was clearly visible when converted from hex (see attachment).
I changed it back to my SN and flashed it, I can use my current probe without manually changing the settings again!
Thanks dude.
