Author Topic: TDA2003 Audio White noise fix (Qixiang/Quanzhou PCB's)  (Read 1745 times)
Offline GEuserTopic starter
  • Is Leaving
« on: August 23, 2016, 01:40:31 pm »
Q
« Last Edit: August 30, 2016, 12:54:09 pm by GEuser »
Soon
Offline CJay
Re: TDA2003 Audio Amp White noise fix
« Reply #1 on: August 23, 2016, 05:23:20 pm »
In the recently newly acquired transceiver (4months?) the hiss is atrocious , in the few years old transceiver its just bearable but now also going to be adjusted , those TDA2003's for those that do not know are very common in the previous several years across several brands of radio transceivers , Anytone , CRT , CRE , and some American branded ones but the pcb's nearly all come from the same place and it would not surprise me that all would suffer from the same thing , all for the sake of 20 cents the cheap bastards , they obviously do not listen to these things do they!
All those Qixiang radios suffer roughly similar problems.
They are a lot of radio for the money though and with a mod or two they can work really well.
