Got any pics? Could be just a toast polarizer.
The service option has to be enabled by pushing a button in the rear. Check the service manual, page 5-2.
Hi George - what sort of pic would show the polarizer was buggered? I think the polariser is a plastic film on the LCD face? Is that correct?
I'm more that happy to take some photos if I knew what sort of pic would help. The displayed characters are pretty weak and would be hard to show in a photo.
Thanks for the tip on the service button on the rear. I'll check that option out now.
Yes, that's correct. There are actually two polarizer films, one in the front, one in the back of the LCD panel. Both can fail.
A toast polarizer will usually have a telltale discoloration, normally radiating from the center of the display, unless it's so far gone that the discoloration has taken over the whole panel, but by that point you would probably see cracks from the degraded adhesive as well. It often also smells unpleasant. A head-on picture of the display with the scope powered on should be sufficient to confirm, but if it seems normal to you (i.e. the same as it looked before you left it alone a year ago), then the polarizer is probably okay.
