I recently acquired a Tektronix TDS 620A oscilloscope. It has the brightest, sharpest, clearest displays of the dozen or so 620's I have seen over the years. That is for the first half hour of operation. After about 30 minutes of operation, the display starts to fade, and fades to a completely dark screen within a minute or so. During the fading the image stays in focus, does not distort to any degree, simply fades away. A monitor hooked up to the VGA output still performs perfectly. Almost certain to be a component overheating, but which one. The driver board is buried with no possible access while operating. Cannot even access sufficiently to use cooling spray to determine the bad component or components that way. I did disassemble enough to look at the component side of the driver board. It looks pristine, no sign of overheating of any sort. Cannot imagine something overheating to cause this issue and not showing some signs of the overheated component, but that is the case. Let the scope cool down for 15 minutes and it is good to go for another 30 minutes or so.
Has anyone seen this problem before? Any ideas as to what the cause might be will be greatly appreciated. As far as I can tell the schematics for the board are not available, if anyone knows differently, that would help (maybe). Even ideas as to how I might track down the bad component not being able to access the board while operating the scope would help. I am hoping the someone may have seen this problem in the past.
Again, any suggestions will be appreciated!
