Author Topic: tds 724 metal cover dont give up tektronix  (Read 810 times)
Offline Rollin HandTopic starter
« on: March 11, 2019, 05:39:45 pm »
I got this scope non working,Im trying to get the metal blue cover out but onlt moves 21 -2 inches to the back and then becomes very tide,I dont see the cover deformed.
Im getting 2 woodworking clamps That i can reverse the tips and do expansion ,This can work ?I can only expand up to 20 30 pounds.
I dont want to damage the internals. Thanks
Offline picburner
Re: tds 724 metal cover dont give up tektronix
« Reply #1 on: March 11, 2019, 07:44:33 pm »
You can find the disassembly instructions in the service manual.
It is better to remove the case vertically by gently waving the case itself during the extraction.
« Reply #2 on: March 11, 2019, 10:37:32 pm »
I have another  tds and that went easy ,vertical ,but this one  does not go.
if I canot do it with the c clamps expanders I will have to use a dremel to cut the cabinet.
