Author Topic: TDS 744A diplay driver board. Help please.  (Read 1142 times)
Offline eurgencaTopic starter
  • Country: si
« on: May 04, 2020, 08:13:23 am »
Hello.
I am having trouble with TDS 744a display driver board. Picture is narrow on horizontal deflection. Horizontal position and size potentiometer are working, but still missing 1/3 picture.
So far:
 I replace all elcos in horizontal stage
Check all power lines 25V, 21V and -12V all o.k.
Deflection coils are O.K. Tested with other CRT.
I made some measurement on friends scope (Green color) and only difference on my board (Red color) is on emitor of Q205 and collector Q245. I desolder and check Q245, CR156, CR208 and Q205 but it all looks o.k.
Like I say C238 and C243 was replaced.
So what on earth can be wrong with this board?
I test other caps and resistors (with DMM) and looks fine.
Any help or clue will be fine.
Thanks, Sebastijan.
Offline shakalnokturn
Re: TDS 744A diplay driver board. Help please.
« Reply #1 on: May 04, 2020, 10:12:28 am »
C323, C221 then C302, C305, C216 ?
  • Country: si
« Reply #2 on: May 04, 2020, 11:12:25 am »
Hello.
C323 and 221 was replaced. C302, 305 and 216 was tested, but with DMM. I don't know if this is o.k. could be leaked on high voltage?
Seba.
Offline CaptDon
  • Country: is
« Reply #3 on: May 04, 2020, 12:14:36 pm »
Possibly something in the size regulator section is wonky?
Perhaps the I.C. is bad? Not often recommended, but perhaps
run a fly lead from the output of that I.C. to the outside of the
chassis where you could just for a brief moment touch it to ground.
That would turn off the size regulator transistor and allow more
deflection. If nothing changes then you may have a clue to what
is going on. Is either of the size regulator transistors (the ones
after the I.C. leaky or bad? That would hold the sweep down.
What about the drive to the horizontal output transistor. Does
it compare to your friends good board? Those boards are a P.I.T.A.
to troubleshoot do to their location. I had a complete external
test jig for repairing those CRT driver boards. You must be extremely
careful to ground the external aquadag/shutter assembly or the
whole thing will be destroyed if you are going to 'bench test' it!!
« Reply #4 on: May 04, 2020, 12:45:33 pm »
Any loose or missing inductor cores?
  • Country: si
« Reply #5 on: May 04, 2020, 02:05:19 pm »
Hello.
Further testing.
Replacement C302 is not helping. If I ground pin 7 of LM358 got VERTICAL line on center CRT. If I disconnect horizontal yoke clearly got VERTICAL line but on colector Q245 then I have 23V. Is this mean that problem is betwen j305 and Q205.
Aha no lose or missing core around inductor.
« Last Edit: May 04, 2020, 09:02:03 pm by eurgenca »
Offline CaptDon
  • Country: is
« Reply #6 on: May 04, 2020, 03:41:09 pm »
On closer look at the schematic I see the 'size' section is actually
the B+ supply to the horizontal output stage. Sorry, I missed that.
When you said a 'horizontal' line on the display, I would assume
actually there was no horizontal sweep at all and the line on the
display was vertical up and down??? Looking at the schematic,
grounding pin 7 would have turned off the B+ to the horizontal
yoke driver and collapsed the horizontal sweep.
  • Country: si
« Reply #7 on: May 04, 2020, 09:00:19 pm »
Sorry my mistake.
 I get vertical line not horizontal. :palm: :palm: :palm: :palm: :palm: :palm: :palm: :palm:
  • Country: si
« Reply #8 on: May 04, 2020, 09:20:43 pm »
Yes B+ go thru Q245 and CR 156 to T150. So if horizontal yoke is disconnected and I have 20V on collector of Q245 I suppose that I have leaking thru C216 or CR307 or this can affect on feedback to pin4 of U350?
 I will order C305, C216 and CR307 becouse this is my first target.
Just for info I found R311 with  resistence of 40K but no signh of burning or discoloring.
Offline CaptDon
  • Country: is
« Reply #9 on: May 05, 2020, 12:43:55 am »
I would suspect you would still have voltage on the collector of
the output transistor even with the yoke disconnected. The feed
is to the collector and not through the yoke look where the transformer
lead goes to the collector path.
  • Country: si
« Reply #10 on: May 23, 2020, 08:54:17 am »
Hello.
Yesterday I have time to play with board. I replace C305, C216 and CR307 but no luck. So I remove Q245 and put DC/DC converter between E and C. Voila it works. If I adjust voltage I can set picture. So Q245 is marked with F2955 can anyone confirm that this is original transistor, becouse it was soldered. Is this transistor MJF2955 or something else?
Sebastijan.
