I am having a problem with our Fluke 5500A and haven't been able to find a way to operate it.
A colleague wanted to control the calibrator via RS232 for testing purposes (to write test procedures).
To do this, he changed the port setting from GPIB to RS232 in the setup menu.
Now, here is the problem: while the left side displays "0mV" and "Standby," there is no longer any display on the right side,
And the device only responds to button presses with a short beep.
If you hold down the "RESET" button while turning the unit on, the display shows "Reset Key held" as described in the manual,
But there is no corresponding output at the serial port. We were unable to establish communication (using a null-modem cable, 9600/8/N/1, host port) and could not get the calibrator back to a state where it could be operated normally.
Power cycling the unit did not help either. Up until this port change, the 5500A worked perfectly, and GPIB communication was trouble-free; we simply hadn't used the serial port before.
It is not being detected via the GPIB port either.
Is there a way to reset the calibrator (jumper, dip-switch, key compbination) so that it returns to normal operating mode?
To be honest, I’ve also got a request in with the Fluke service desk, but you know how it is... you try anything that saves time.
Greetings
Andreas
