optocoupler is a problem for change, since as the circuit design, the optocoupler has the certain trigger current, but after several years, the old optocoupler type you can not find it, even you can buy same type, but they all dismounted from old PCB, I ever tried to buy same optocoupler six times, each time, the test parameter is different.
