Good morning,
some news from my E3610 power supply.
After applying all recommended changes (thank you to "Free_electron" for the link), range switching still does not work (8v/ 15v).
The list of amendments is as follows:
_replacement of all electrochemical capacitors
_Suppress C5 and C4
_Replace C12 with 470uf 50v
_installed resistance R 46 (bleed resistor)
_installed capacity 220pf paralel on R6
Then check the voltages at the different test points and everything seems OK (+12V, +5V _1, +5V_2, -12V, and V Tp2)
. Note that V Tp2 changes well when you switch the range!
As the output voltage still does not switch according to the range, replacement of integrated circuits U1, U4, U5.
The range control still doesn’t work!!!
Then I also checked Q2 and the transistor works (hfe = 50).
Here’s where I am and I don’t know what to do
. If you have an opinion on this strange breakdown, I would very much appreciate your help.
Thank you
Remy
