Hello, I'm trying to match a LCD driver with 640x480 display directly to the VGA connector J88 found on most color or mono TDS500/600/800 main board (video section). In order to fine tune the LCD driver internal scaler vuideo chip, I need to know precisely the pixel or dot clock generated by the TDSxxx. Unless I'm wrong, my understanding is that quartz near ADV471 does this job at 24 MHz (printed on the quartz) but when measuring ADV471-40 pin (chip U199), it shows 25 MHz.
I've tested this value both on a mono-color TDS520D and color TDS784D, both generate 25 MHz instead of what is printed on the quartz (24 MHz) near to the U199 chip.
Do you know the pixel clock value is generated by another ASIC or dedicated tektronix chip or what could the explanation of 1 MHz difference ?
Note about color model, there is another quartz 80 MHz to drive specifically the shutter found on the CRT, here I'm only interested on the VGA output signal found either on J88 internal connector or external VGA connector.
Thank you, Albert
