Author Topic: TDS540 no picture (debug logging added)  (Read 1756 times)
Offline charlydTopic starter
« on: January 02, 2018, 03:28:01 pm »
Hello i got a TDS540 over here. the unit powers-up and it gives at the end -> wandering 2 left digits  on the display ( i would say looks good )
[what happened the days before....]
-  Replaced the SMT electrolytic caps on every board, so also the fron tpanel.
-  Plus a thorough degrease and clean on the boards and cleaned with IPA.
[What needs to be done still...]
- NVram swap ( but it give no error yet at this moment so first fix picture)
after over checking all the work done yet..i putted it back together and ran a debugging log  at the console port while booting:
Bootrom Header Checksum passed.
        Bootrom Total Checksum passed.
        BootRom Check Sum passed.
        Bus Error Timeout test passed.
Kernel Diagnostics Complete.
Calling SDM (monitor) Routine.
        Enabling Bus Control register. Value = 0x67
        IMR 1 Register test passed.
        Misc. Register test passed.
        Timer Interrupt test (Auto-Vector) passed.
        NVRam DSACK test passed.
        NVRam Write protected.
        Flashrom DSACK and JumpCode test passed.
        Flashrom Checksums passed.
Bootrom Diagnostics Complete.
Transferring control to the Flashrom.
-> Console Loopback O.K. <-
  ^^          ^^         VxWorks Development System
            VxWorks version 4.0.2.
            Stripped Stand Alone Rom Version.
            Columbia Proc. Brd. Rev GG065801
            System Ram Size = 1048576, Proc ID = 0x18
            Clock Interval = 13108 usecs,
            Bootline Storage Size = 296 stored @0x4000068
            Flash ID = 0x0, Flash Wait states = 2 (Misc. reg = 0x14),
            KERNEL: WIND version 1.0. GCC COMPILED
            Copyright 1991-2001, Tektronix, Inc.
            made on: Wed Feb 12 15:28:50 PST 1992.
            copyright Wind River Systems, Inc., 1986, 1987, 1988, 1989
Executing Diagnostics
ERRORID: 149 diagnostic test failure Start Power-On Sequence
Start Power-On Diag Sequence
hwAccountant probe routines
  Probe for unexpected pending ints
  Dsp Instr mem size
  Dsp D2 mem size
  Dsp D1 mem size
  Dsy Vect0 mem size
  Dsy Vect1 mem size
  Dsy Wfm0 mem size
ERRORID: 149 diagnostic test failure initVSC()
  Dsy Wfm1 mem size
  Dsy Text0 mem size
  Dsy Text1 mem size
  Acq number of digitizers
  Acq mem size
  Cpu timer interval uSec
  Cpu Dram size
  NvRam mem size
  Opt RS232/ Cent presence
ERRORID: 64 wrong hardware configuration Dsy Wfm0 mem size probe, expect: 1ffff,
 actual: 0
ERRORID: 64 wrong hardware configuration Dsy Text0 mem size probe, expect: ffff,
 actual: 0
dspForcedBus ................... pass
cpuDiagD2MiscReg ............... pass
cpuDiagDSPIntMaskReg ........... pass
cpuDiagD1D2Access .............. pass
cpuDiagDsyAccess ...............
Bus Err
After that i booted the unit with ACQ & Front panels disconnected still the same no picture.
( so only the cpu/dram board connected to get a picture ).
i checked U190 back to U81 but get lost there, i assume some prerequisites are not in place yet. The boot process doesn t come to an end.  no ticking relays from inputs and all ( when connected) channel leds lite.
anybody experienced with this problem.. or where to look/check. ?
« Last Edit: January 02, 2018, 05:08:06 pm by charlyd »
Re: TDS540 no picture (debug logging added)
« Reply #1 on: January 02, 2018, 05:15:48 pm »
as for the logging it would suggest to check  ERRORID: 149 diagnostic test failure initVSC()
so the troubleshoot should be....
Run the dsyDiagVscDiagReg diagnostic in loop.
This standard register test exercises U81 and its associated Circuitry.
See Diagnostic register test description for details.
repair any adress bus errors on inputs of U81
any suggestions where to get the dsyDiagVscDiagReg diagnostic
« Last Edit: January 02, 2018, 06:55:45 pm by charlyd »
Offline fenugrec
« Reply #2 on: January 02, 2018, 08:24:55 pm »
Have you tried entering dsyDiagVscDiagReg on the service console port ?
« Reply #3 on: January 04, 2018, 08:45:37 pm »
thanks for your response.
No i didnt try but i have to run it in a loop. How do i do that, run in a loop on the console port ? i think it is a toolkit from Tek.
if it is not the case and usable in a way please let me know...
« Reply #4 on: January 21, 2018, 09:18:06 am »
because of the error
 Dsy Wfm0 mem size probe, expect: 1ffff,  actual: 0
Dsy Text0 mem size probe, expect: ffff,  actual: 0
i was looking arround on the the U71,U72  and the U108-U111 but i can not find any missing or broken dataline.
i would suspect that  getting 0 where to suspect 1ffff  would end up finding a missing like  0001 1111 1111 1111 1111
and where to suspect ffff (like 1111 1111 1111 1111) i am getting a 0.
I probe arround a whole day but didn t find any things in that area so i hope somebody else had such a error and can point me in the right direction.
to make things more simple the circuitry of WMF1 and Text1 are not implemented on this board.
any suggestions..
« Last Edit: January 21, 2018, 10:08:47 am by charlyd »
« Reply #5 on: January 21, 2018, 05:00:17 pm »
this afternoon i tested the comands like : dsyDiagVscDiagReg  on the console port. Two things or it is not working or i do something wrong...
if anybody is experenced with VXworks commands please jump in this topic..
