Picked up a TDS540a in good condition (no sign of cap leak, everything shiny & clean, passes self-test, and displays 4 channels). The only problem is the display ends short. See attached.
This might be a bad joint or reduced voltage, just wondering if anyone has seen this before and can point me in the right direction...
I thought I might be able to tweak the vertical joke adjustments, to see if they are a factor, but they appear out of reach. I suspect a disassembly is on the cards with being careful of the high voltage on the anode lead (ground it to chassis).
Update:
Looking at the display, it seems 'shrunk' horizontally as well compared to my 540. That makes me think the LM317 circuit regulating the 24v down to 20.5v that powers the whole display driver circuit could be worth investigating. Either the adjustment is out, a bad solder joint, or we have a bad cap or two. or the input 24v is down and it's out of headroom. Start from the input...
