Author Topic: TDS544 Schematics? - Bad -15v Power Supply  (Read 1396 times)
Offline daveykTopic starter
« on: April 22, 2017, 07:36:16 pm »
I found the service manual but no schematics.   The -15v supply J26-7 is only -12.5 with the ACQ board un-hooked.  So my problem appears to be that  main big power supply.  I a not sure how to fire it up outside the scope in order to trouble-shoot it.  If I pull the digital board off, the I can not turn it on with the front panel.  There is probably wiring to turn on the power supply, but without prints, I don't know how to do that.  Even if I can figure out where the -15volt supply is, I could possible shotgun it.
If someone has prints could you please send them to me, or reply with a link?
Thanks so kindly,
Dave
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
Re: TDS544 Schematics? - Bad -15v Power Supply
« Reply #1 on: April 23, 2017, 02:26:02 am »
Sorry, I don't have any links but I just wanted to suggest keeping this scope repair in a single thread. It appears you've created several threads for the same issue?
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
« Reply #2 on: April 23, 2017, 05:42:16 am »
Sorry, I'm not sure how but that was with the iphone. I tried deleting my threads and the forum won't let me.
