Just had this TDS684B scope come across my bench for repair. Purchased on Ebay as working:
http://www.ebay.com/itm/141797300530?(Yeah, right. If I had a dollar for every time I've bought something off Ebay as used and fully functional that really was...)
Would pass the power on self tests and SPC, but when the full self test was run from the utility menu, it would fail with the following errors:
"Thu 10-29-;5 13:58:28 ERROR: diagnostic test failure, digFisoShortPipeDiag, ffffffc4 <= exp <= 3b was = -61, CH2: addr = 7340004, BWL=20MHz";
"Thu 10-29-;5 14:08:08 ERROR: diagnostic test failure, digFisoShortPipeDiag, ffffffc4 <= exp <= 3b was = -61, CH2: addr = 7340008, BWL=20MHz"
"Fri 10-30-;5 06:37:03 ERROR: diagnostic test failure, digFisoShortPipeDiag, ffffffc4 <= exp <= 3b was = -61, CH2: addr = 734000c, BWL=20MHz"
Found two unsoldered pins (51 and 52) on the A/D converter for CH2. This fault was there since it was originally manufactured in the 90's!
Looking back through the logs, the first occurrence was in 1999. One would think that it was probably worth having Tektronix repair it. I wonder if it was under warranty then?
Took a picture - wish I had a better camera.
Jay
