I tested Q7 and Q8 I think they are OK.
I meant that the higher voltage was on these transistors Q7 and Q8. They are K3233. Now I get 12-14v from their legs to ground.
FCH30A04 had zero voltage between any legs and shorted between any legs and also with the white diode. Where can I test for input voltage for it?
I will look for a replacement for it.
What you circled green oval is exactly where there was a white diode I removed. What type is it?
I connected 12.5v as you suggested and tested all the points they are all OK. THAT IS GREAT BECAUSE SECONDARY IS WORKING.
Thank you again very much
