FYI to people having a go at these BX series amps:
At the bottom of the main board (hidden underneath) there is usually a cap or two secured by that disgusting amber glue (my personal favourite electronics HATE item
In most cases the affected board tracks may be almost totally eaten away and or intermittent temperature dependent 'bridge work' is going on to cause audio hissing n crackles, and other unexplained headaches
i.e. I would strongly suggest to sort this out first before moving on to the next troubleshoot/repair procedures
fwiw the gunked greencaps are usually ok and reusable after a clean up, and solder some wires or whatever on the eaten tracks.
Check the amp for other 'innocent looking'
glue affected areas too, and sort them out asap
I have saved a few this way without troubleshooting any further for issues,
and own a couple, nice cheap decent linear performance amps at low to moderate loudness levels with efficient loudspeakers
and not too shabby waveforms on the oscilloscope
