Author Topic: Tear down of cheap Amazon decade resistor box  (Read 3527 times)
Offline RNATopic starter
« on: December 07, 2022, 11:44:49 pm »
So I thought I would check out these cheap decade resistor box from Amazon £16.
I mean how bad could be?  :palm:
https://youtu.be/8_Qgr17ZWR0
The following users thanked this post: Kleinstein, capt bullshot, Grandchuck, Wallace Gasiewicz, fzabkar
Offline TheMG
Re: Tear down of cheap Amazon decade resistor box
« Reply #1 on: December 08, 2022, 02:29:16 pm »
Can't say I'm surprised. The switches are the most important aspect of a decade resistor box in order to yield reliable, repeatable results. Good switches of this kind don't come cheap.
Then again, they could have improved that design quite a bit without significantly adding much cost.
« Reply #2 on: December 08, 2022, 10:30:07 pm »
What do you reckon about something like these
 https://www.mouser.co.uk/ProductDetail/Grayhill/50P36-01-1-10N?qs=ls7QRyWmRk4Syk7DsxOJAQ%3D%3D
One could make quite a neat compact pcb with six ranges of
100k
10k
1k
100 ohm
10 ohm
1 ohm
« Last Edit: December 08, 2022, 10:33:22 pm by RNA »
Offline trobbins
« Reply #3 on: December 09, 2022, 02:06:10 am »
Why would you use Grayhill when imho the Alpha's likely suit the rest of the parts?  I don't recall seeing that you determined the nominal accuracy of the step resistors, or considered a max voltage/dissipation rating to suit their tempco and your application expectations.
https://au.mouser.com/datasheet/2/13/taiwanalpha_12112018_SR2612F-1509903.pdf
Offline testpoint1
« Reply #4 on: December 15, 2022, 05:34:33 am »
if you need the accurate calibration tool, you can find a used "General Radio" kit, made in MA USA, but the factory already closed more than 30 years.
Offline factory
« Reply #5 on: December 16, 2022, 07:36:35 pm »
And hope the previous owner/user hasn't burnt all the precision resistance wire in the lower ranges.
Or it's not rotted away on the higher ranges, from being abandoned in a damp shed/loft/garage for 20+years, as in some Muirhead ones I have.
Having said that I have two nice Cropico boxes, that cover the ranges of the dead Genrad box.
Also have a smaller sized general purpose decade box, of lower spec from Cropico.
« Reply #6 on: January 11, 2023, 06:54:09 am »
So over the holiday break my curiosity got the best of me.
I must be clear that my intended use for decade resistor boxes is for the resistors around an opamp to play around with scaling.  Maybe using it to select the brightness of an LED current limiting resistor etc.  Nothing critical.
So I made a prototype by soldering SMD's to a Lorlin switch and was surprised how well it worked.
I decided I would give it a go in kicad and get some made up at PCBWay.com
I will make a video when they arrive and report on how well I did.
Also. I decided not to use banana plugs as there are so many different mounting types and went for soldering breadboard wire for a better connection.
« Last Edit: January 11, 2023, 06:58:34 am by RNA »
« Reply #7 on: January 11, 2023, 03:20:29 pm »
It is so nice when the 3d Models all match up correctly lol
Offline JimKnopf
« Reply #8 on: January 17, 2023, 12:07:58 pm »
I bought a a similar Mao era style resistor decade a while ago. Too big and not very accurate.
I build this one from thumb wheels. One with old-style metall film resistors, one with SMD parts.
« Reply #9 on: January 17, 2023, 04:20:07 pm »
What do you think was the cause of the inaccuracy?
Offline JimKnopf
« Reply #10 on: January 17, 2023, 09:04:35 pm »
Bad design, bad manufacturing, cheap 5% resistors.
« Reply #11 on: January 18, 2023, 11:53:27 am »
haha that's the same style as in my original video i posted.  I wonder how many of this useless design they have made?  They are all over Shamazon.
« Reply #12 on: February 09, 2023, 02:36:32 am »
oooh things are coming together now
« Reply #13 on: February 15, 2023, 02:43:56 pm »
I am pretty pleased with how this turned out!!  I will make more videos when i can.
https://www.youtube.com/shorts/lhreDVdqf4k?feature=share
« Last Edit: February 15, 2023, 02:46:01 pm by RNA »
Offline TomKatt
« Reply #14 on: February 15, 2023, 03:18:20 pm »
Very nice job!
I much prefer rotary switches to the slide switch designs.
Nuts & Volts has a good article about building both resistor and capacitor decade boxes here: https://www.nutsvolts.com/magazine/article/September2016_Capacitor-Resistor-Substitution-Boxes
Often you can find good quality switches at surplus electronic suppliers that are much cheaper than Digikey etc.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PIC
Offline Hamelec
« Reply #15 on: February 16, 2023, 08:44:10 am »
Better to use Lorlin CK1059 = shorting type
« Reply #16 on: February 16, 2023, 01:30:27 pm »
Yeah. ice idea, and ideally I would like short stubby d-shafts so not have to deal with grub srews.
Offline Hamelec
« Reply #17 on: February 16, 2023, 02:49:52 pm »
23 years ago..
Offline TomKatt
« Reply #18 on: February 16, 2023, 03:47:34 pm »
The following users thanked this post: HobGoblyn
« Reply #19 on: February 18, 2023, 12:33:40 am »
Haha that funny, and potentially confusing lol.  When I designed my decade resistor box I originally had ten resistors.  Limiting to 9 is much easier on the old brain.
One thing that sets my design apart from any lets say non western country is the order of the units.
Mine goes from hight to low as opposed to many others I have seen.
https://youtube.com/shorts/RLTFAFxopnI?feature=share
Offline TomKatt
« Reply #21 on: February 24, 2023, 04:32:07 pm »
That virtual op-amp page is pretty slick!  8)
