Hi guys,
My Seek Thermal Compact Pro (Micro USB) went bad and I was tinkering around and tried to wire an external Micro USB male connector. Unfortunately, the ribbon cable was torn and I am not sure if I remapped the pins on the board correctly. I have attached a picture from the PCP of the camera with the ribbon cable connector removed. I have labeled the pins which I assume are the correct mappings. Does anyone know the pinout and can help me with the wiring?
Thanks so much! It would be a shame if the camera did not work just because of the wrong connections.
Cheers
Markus
