Author Topic: Tektronix TDS5032B Diagnostic Failure  (Read 416 times)
Offline trieckTopic starter
« on: February 24, 2023, 03:50:22 pm »
I purchased a Tektronix TDS5032B on eBay that was not working.   I was able to repair it by re-capping the motherboard, replacing the power supply and replacing the memory.  However, when the TekScope.exe application launches, I receive a diagnostic failure on one test.  The test is called LineTrig under the HITL (Hardware In The Loop) area.  The result of the test is code 445.
I haven't been able to find a lot of information about this error.  From what I understand, the line trigger would typically be associated with a TV or video signal.
Any help in tracking down information about this error or where I might begin to think about repairing this would be greatly appreciated.
Thanks
« Last Edit: February 24, 2023, 03:52:54 pm by trieck »
Offline voltsandjolts
Re: Tektronix TDS5032B Diagnostic Failure
« Reply #1 on: February 24, 2023, 04:45:12 pm »
Power line trigger, like 50hz or 60hz
Maybe related to changing psu
Was there a loose wire pickup taped to the incoming live line
Offline mikehank
« Reply #2 on: February 24, 2023, 08:35:08 pm »
Line trigger input comes directly from the power supply.  It is the frequency of the input AC.  60 Hz for north America.  Look at the power supply it looks like a common ATX supply but it has a couple of non-standard connectors.  I would start there.  I don't think I've seen the ACQ board cause line trigger failures.
