I have the 18GHz FSL that has recently stopped working right. It passes all self tests but acts like the analog input port is disconnected. The signal amplitude is small for all setting except for the 40db attenuation setting. There are two input ports to the spectrum analyzer board that gets the signal from an RF SPDT relay that seems to switch in and out a 10dB attenuator. I believe the attenuator is functional as it measure 60ohms on the input and 16 ohms on the output when out of circuit. The switch has a DC blocker on the input and it measures 0.47uf from input to output so I believe that is functional. I would appreciate any tips where to look. It seems to be an issue very early in the signal path. I have not verified that the RF relay is functional but in operation I here relays clicking when sweeping through attenuator settings.
Thanks,
Dennis Eldred
