Author Topic: Teardown, Repair & Analysis of an Agilent N5230A 13.5GHz PNA-L Network Analyzer  (Read 3459 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
Please let me know what you guys think. We can decide on how to proceed.
You can watch the video here: [51 Minutes]
youtu.be/665-hwI8reQ
More videos at The Signal Path:
www.TheSignalPath.com
Offline edpalmer42
Do you know Luis Cupido?  https://www.qsl.net/ct1dmk/ and, I think, https://groups.yahoo.com/neo/groups/chip-hybrids/info .
He might be willing to do the repair.  At least, his advice would be valuable.
Ed
Offline rx8pilot
This will be very interesting to watch! Even if the attempt does not work.... seeing the process unfold will be rather cool.
Short and misplld from my mobile......
Offline dcarr
Even if a bonder is available, how does one obtain bare die switches, FETs, etc. in single unit quantities?
DK, etc. show minimum orders of 25,50,100 units!
Offline TheSteve
  • Living the Dream
Seems like it would be a bit of a waste to experiment too much with it using QFN's etc. However if you got a wire bonder then absolutely swap in a new switch.
VE7FM
Offline rx8pilot
Curious what level of wire bonder would be appropriate for this job. My best guess is that a fairly basic and old, but working one would be ok. No real need for the ultra-deluxe sub-micron computer vision based systems.
Thank you all.
Looking for a unit, but so far can’t find a reasonable one.
I’ll keep you posted.
Offline vaualbus
Is not possible to bypass the amplifier on the 13ghz path and put an outside amplifier to regain that 20db of loss you have? And Than bypass the ALC circuit to look at the power after the "outside" amplifier?
Offline rx8pilot
Thank you all.
Have you done this process yourself, or do your technicians typically do this type of process? I have seen the machines, but have no reference for how they work or what kind of skills are needed.
I have procured the finest popcorn and butter for part 2.
Thank you all.
Yes, I have done wire bonding before. As with any skill, practice is required. :)
Offline Magiciaen
This die will do the trick I think, and it's only $30, available in single quantities from Mouser:
https://www.microsemi.com/existing-parts/parts/137221
https://www2.mouser.com/ProductDetail/Microsemi/MMS006AA?qs=%2Fha2pyFadug8ZHUc9uYNv83PfExVK2BiIJof%2FYl58no=
I'd wirebond it for you, but don't have access to one at the moment. I think getting access to a wirebonder through a colleague and making this process part of the repair video would be really instructive to viewers!
