Author Topic: Technic SU-X501 amp repair help needed  (Read 2048 times)
Offline motorhomer
« on: November 17, 2017, 11:07:10 am »
I have a Technics SU-X501 amp which I got to learn electronic fault finding. This is my first project fault finding on amps. I have done electronics with Arduinos and I have built small amps and valve amps so have some knowledge of electronics but never gone into service repair which is where I would like to go.
I would like some help with the current amp I have as the fault on it seems to be more difficult to find than I intended to start with. Initially the amp was reported to not start up. I found four PCB tracks cut on the front panel which supplied the LCD and the 6.1V / GND to the Microcomputer. I have bridged these out and now it powers up with display.
There was a power issue the relay would click on/off and the negative -15 voltages across the board would fluctuate. I have re-soldered the regulator transistors in as they looked like dry joints and now the supplies seem all ok.
The issue I have now is with the selector chip TC9164N. initially when putting a signal through the amp there was no control over the selection of the input. A signal on CD would play no matter what was selected on the control panel. So, I changed the selector input chip but I still have the same issue.
The supply voltage to the chip is correct 14.8v on pin 28 and -14.8v on pin 1. If I put a 1000 Hz signal through the CD input I get this signal on the inputs to the chip at pins 8 and 21. I then get the signal on pin 9 output for right channel no matter what is selected on the front panel but nothing out on pin 20 for left channel no matter what is selected. I have checked the DATA signal and seem to get some data through when selecting an input on the front panel but the CK signal seems to not do anything, not sure what I should be getting on this pin or what I should be getting on ST pin.
I have removed the coupling capacitors to the pre and power amp C301 & 302 but the fault is still the same. Maybe the power amp has blown this chip a second time or the chip was faulty from supply. I have ordered two more selector chips to try.
I am now a little stuck not knowing what next to try. Has anyone worked on this amp and had similar fault. Any advice help would be great. I would love to get this fault fixed so I can move onto the next learning curve. Thank you in advance for any help
Service manual
https://cyqvlqsfs.files.wordpress.com/2015/08/technics-su-x501-user-manual.pdf
Offline modrobert
  • Country: th
    • your console hacking resource
Re: Technic SU-X501 amp repair help needed
« Reply #1 on: November 17, 2017, 02:20:14 pm »
I can't help you with the problem, just wanted to mention that the "service manual" you linked only contains links to a malware site, not an actual manual.
Offline motorhomer
« Reply #2 on: November 17, 2017, 03:54:06 pm »
I used this link clicked on the first direct link the the service manual for the amp down loaded. if i find a better link i will put it on
This is another link for the manual
https://elektrotanya.com/technics_su-x501_sm.pdf/download.html
« Last Edit: November 17, 2017, 05:16:25 pm by motorhomer »
Offline YU2
« Reply #3 on: November 17, 2017, 04:57:39 pm »
Pcb tracks were cut intentionally or the board cracked?
Offline motorhomer
« Reply #4 on: November 17, 2017, 05:47:39 pm »
Cut, looking at it the tracks where next to the securing screw for the PCB. I expect the previous owner may have slipped when doing up or undoing this screw and the driver cut through the tracks. The PCB is all ok
Offline YU2
« Reply #5 on: November 17, 2017, 06:50:50 pm »
I would say power transistors were the main problem with amp.
Selector chip problem probably occurred when front pcb was removed.
So again carefully check it, some smd component could cracked from bending.
Offline mzacharias
« Reply #6 on: November 17, 2017, 11:33:30 pm »
Service manual
If your source input is plugged into the "Rec Out" jacks, the sound will appear on any selected input.
Offline motorhomer
« Reply #7 on: November 22, 2017, 12:45:57 pm »
Sorry for the late reply, i had some issues with using the phone as a signal generator. My new generator has now turned up so i can carry on with the testing.
I have removed the IC201 (TC9164N input selector) and wired in the generator at 10000Hz stright into the output pins 9 and 23. I found a dry joint at R302 right channel which I have sorted. The amp will now pass the signal through to the output speakers both channels with volume control. So it looks like the power amp and tone controls all work ok.
I checked the DATA, CK, ST signals to the chip and I was getting the following.
DATA - 1 pulse different width for each selection
CK - different number of pulses for each selection
ST - NOTHING
So checking the front CPU the ST was pulsing one pulse each selection. I found another broken track next the the CK track which was also broken.
This is where i am at the moment. I have repaired all tracks and have the DATA, CK, ST signal at IC201 with the chip removed.
With the chip back in i then get a lot ac noise on the data signals and with no signal inputs connected.
playing music through the amp it plays very well no hum and I have all tone/volume controls
When selecting other inputs the amp still does not change channels but has a click on the speakers each time a channel is select
This is the second selector chip fitted and still I have no selection of the inputs. The noise on the data lines may be an issue. I have an ESR tester on the way so I can test all the caps to see if they are failing.
I am also thinking setting up an arduino to test these chips see if they are failing from supplier or failing when fitted.
Below is another link to the manual through my google drive let me know if this does not work.
https://drive.google.com/file/d/1o9IBB3qA9oTIFPELvhgNkEvBqX7wqp0A/view?usp=sharing
Offline motorhomer
« Reply #8 on: November 24, 2017, 10:00:42 am »
Finally got the amp changing over with selector switch intput. Found another dry joint on the Clk pin to the board and I believe the DATA track on the PCB was shorting the the CLK track so I have isolated this track seeming as I have now done a direct link from the input pin to the CPU bypassing this damage.
I powered the amp up on the bench and it played very well both channels and I now have input selection. Everything was worked great.
Boxed the amp up and cleaned it, powered it up for another test showing off to my son who is also interested in learning and on power up the magic smoke appeared. No son this is not the smoke machine effect it has blown out the voltage power transistors now.
I did do some soldering on the regulators as one pin looked bad and I did not clean off the excess flux. Could flux conduct enbough to blow out the regulators or is this amp just refusing to work.
Will have to now order some new transistors and try again
« Last Edit: November 24, 2017, 03:23:47 pm by motorhomer »
Offline motorhomer
« Reply #9 on: December 02, 2017, 10:48:16 am »
Got some time testing on the amp last night and have found the problem was with R702 and zenor D702 which supply the base to the power transistor Q704. I tested Q704 and that was all ok. Replaced the burnt-out components and powered the amp up. All supply rails are now correct, and no more smoke 😊. But after about 5 min playing music I get a click and no more sound. Powering the amp off and on I get sound for a while the again relay drops out and no sound. I believe this is now going into protection mode but not straight away on start up. I hope this is not the power chip and this becomes expensive.
Offline Riotpack
« Reply #10 on: December 16, 2017, 03:01:47 pm »
Carefully inspect the PCBs for dry joints and broken tracks especially around large components and those which get hot.
Offline Cyberdragon
« Reply #11 on: December 17, 2017, 06:06:28 am »
I don't think any cracked joints could trip the protection. It's usually a short. Obviously check the speaker wires first, but from there it's looking rather grim, the overload detector is in the output amp chip. Check for -42V on pin 8, since you already found regulator faults. Check Q510 for leakage and for -0.8V at the base. If it's not the right voltage, R530 could be open letting it float, but beyond that, your chip is probably dead. Line L from Q510 inexplicably goes to J605B and just ends. :wtf:
*BZZZZZZAAAAAP*
Voltamort strikes again!
