Hi. I got a 30 year old Technics SA-GX100 amp for repairs. I do have a bit of digital electronics experience (mostly self-taught), but this is essentially first time me dealing with analog/power electronics.
So, the patient was brought in with complaint that the screen won't turn on. Standby light is on, upon switching the power button relay can be heard, but nothing else happens. Skimmed through the service manual I popped the case open and straight off the bat saw regulator transistor (Q752 - 2SC3940AQSTA) surrounded by soot. Replaced that with 2SC1384(R) together with zener, just in case replaced most of the electrolytes in PSU. Tried powering up and found out that the main transformer is dead (open on primary, secondaries are fine). Didn't think of measuring that before powering it up, maybe I killed it.
The problem is that I can't find direct replacement for RTP1M5C001AV transformer (center-tapped 54.4 (27.2+27.2) + 3.9V from schematics, no datasheets available). Generally not much is available for specified secondary voltages. So the question is - are those transformer output voltages in schematics no-load voltages (implying that it's actually 24V) or full-load voltages (30V transformer)? Can I replace it with a dual 30V toroid (60V center-tapped) in parallel with some simple 4V source? Or do I really have to rework PSU from scratch to provide necessary +-27.2 as designed by the Germans?
Any help much appreciated
