Author Topic: Technomate TM-TWIN-OE burned IC SD4841P 67k65yw3j0fz , equivalent IC required  (Read 1005 times)
Offline lineofstarsTopic starter
Hi everyone.
Few weeks ago I had a power cut in the building  and after that my satellite receiver got broken. The device display does not work, but the HDD it can be heard that it is spinning.The image on TV got the boot image frozen.
I opened the lid and I found the burned IC: SD4841P  67k65yw3j0fz which is visible burned.
I would like to know what equivalent can be installed since the SD4841P is a bit difficult to find it to local IC store vendors or it takes 2-3 weeks to get it from abroad.
For example if  can be TOP221-227  ,  TNY264/266-268,  TNY274-280P/G    and if yes, from the given range which exactly and why.
Also what can be done to avoid to happen such circumstances.
Thanks in advance
Hi guys.
Good news, the IC SD4841P was replaced on the mother power supply board.
Bad news, when I unscrewed the power supply board, I saw other burned area, as you can see in the pic I send in this email.
The worse scenario, I have searched in Google “B TSFM 10100 10C” and …nothing comparing with the other burned IC SD4841P that I have found suppliers on Ebay. So I do not know what component to search.
That area it belongs to the D3 , on the component is wrote: B TSFM 10100 10C as you can see in the pic attached.
Diagnosis: I have picture on the TV, the “OPENPLI”, but in the receiver, the display does not work, the remote control does not work, the buttons in the front panel does not work.
I have to power off from the back side of the device( the I/0 button).
I can hear the Hard Disk Drive(HDD) spinning , and also the fan.
So basically I do not know the component type to search it , I do not know the manufacturer, the "B" letter printed on the component is not helping a lot in this situation....
So I hope with all my heart someone knows.
Waiting your reply, anything could be helpful.
Thanks in advance.
Offline SpecialK
mbrf10100ct perhaps?
