Author Topic: techtronix 475, U370 does not work?  (Read 1096 times)
Offline cmcdanTopic starter
« on: April 21, 2017, 09:36:30 am »
Hi, Hope to get some info. I am a long time Tek repairman but stuck here. The manual, p26 has a logic chart for U370 inputs. I removed U370 and checked  the 4 inputs; logic is correct but U370 does not output signal. I used hairpin loops to bypass ch 2 and all's well. The voltage level hi -2.30; low - 1.49; This IC had a heat sink; it gets warm but not hot? What to do? cmcdan  solution: bought a replacement from Greece, yes the country. It worked but scope died; HV pwr supply tap for -150V, 50 kHz kaput; made a Lab pwr supply out of rear 7 inches.
« Last Edit: November 07, 2017, 10:46:13 am by cmcdan »
Offline tggzzz
The following users thanked this post: cmcdan
