Author Topic: Teensy 4.1 Ethernet problem  (Read 605 times)
Offline SerhiiTopic starter
  • Country: ua
« on: April 04, 2023, 12:23:51 pm »
Hi everyone!
My Teensy 4.1 is connected to a pcb that has ethernet port. But I can't get connection. It looks that Teensy works fine through a serial port(USB) but when I trying to connect with an ethernet cable no
other devices can see the board(tried with a bunch of computers and router). I blame myself that I fried something while soldering.
Can anyone give me a hint how to check ethernet on Teensy? I have DMM and an oscyloscope. Any information is highly valuable! Thank you for your time!
Offline ZigmundRat
Re: Teensy 4.1 Ethernet problem
« Reply #1 on: April 04, 2023, 03:01:27 pm »
You have to include the Ethernet support in your project of course. This varies by the environment used (PlatformIO,CircuitPython,etc). But until you do this you won’t have a MAC address, much less an IP address. What have you done to enable Ethernet on the software side?
