Author Topic: Tek 2215, strange behavior on CH1  (Read 992 times)
Offline DigitalAuraTopic starter
« on: September 20, 2017, 10:01:45 pm »
Hey Guys, new to the forum and I was hoping somebody had an idea what could be wrong with my new scope I just got off of ebay.
Sine wave kinda looks okay apart from what looks like square wave artifacts...  It gets real interesting when I try to view a square wave.
It would be awesome if somebody knew what was going on here and what I would need to do to fix this, it only happens on channel 1, channel 2 is perfectly fine.
Thanks
Offline David Hess
  • DavidH
Re: Tek 2215, strange behavior on CH1
« Reply #1 on: September 20, 2017, 10:59:04 pm »
You do not give the horizontal and vertical settings but it looks like there is an open in the high impedance circuits before the buffer of channel 1.
Offline cdev
« Reply #2 on: September 21, 2017, 01:57:05 am »
This might be the problem, the little red circle shows the switch for coupling is set to "AC" - It should be set on "DC" to view a square wave.
« Last Edit: September 21, 2017, 02:00:09 am by cdev »
« Reply #3 on: September 21, 2017, 12:22:28 pm »
Nothing to do with settings but thanks anyway.  I'll dig out the service manual and check the first solution though for sure.
