Author Topic: tek 2215  (Read 6014 times)
Online andy3055
Re: tek 2215
« Reply #25 on: October 22, 2021, 06:26:28 am »
Yeah, those are protected files. Check pdf page 157.
Offline m3vuvTopic starter
Re: tek 2215
« Reply #26 on: October 22, 2021, 06:41:16 am »
it gives the location as beeing 2 c,is that on the board with all the controls on,gives a pic of the front pannel board on this manual.
Online andy3055
Re: tek 2215
« Reply #27 on: October 22, 2021, 06:54:34 am »
Get this manual: https://w140.com/tekwiki/images/9/9a/070-3826-00.pdf
Page 157 has the Vertical preamps.
Re: tek 2215
« Reply #28 on: October 22, 2021, 07:35:59 am »
it gives the location as 2c,is that on the board with all the controls on it,ie the front panel board?
Online andy3055
Re: tek 2215
« Reply #29 on: October 22, 2021, 08:08:16 am »
Check page 156. It is on the A10 main board towards the bottom left. Location 2C area.
I saw your posts on Tek Groups.io. Did you try the responses from those people?
It is just past 1 AM for me in the bay area. I am going to sleep. Will catch up in the morning. Brain does not function at this hour!
Re: tek 2215
« Reply #30 on: October 22, 2021, 08:53:50 am »
well i have found them,again a total ass to get to with the crt in situ,looks an ass of a job to remove the crt,it may get put back together and go on ebay as spares or repair,cheers for the help,the tek group io have been no use whatsoever! .
Online andy3055
Re: tek 2215
« Reply #31 on: October 22, 2021, 10:12:28 pm »
I still think you should check the voltages per the service manual on that section. I get the feeling that something has failed there. Since it does this on both channels, it has to be a common thing like power for both channels.
There are some good tips on this thread: https://www.eevblog.com/forum/repair/tek-2215-repair/msg2508945/#msg2508945
« Last Edit: October 22, 2021, 10:24:58 pm by andy3055 »
Re: tek 2215
« Reply #32 on: October 24, 2021, 01:17:28 am »
does anyone know where the voltage test poins are located on this,all i can see is a ground tag/tp.
Re: tek 2215
« Reply #33 on: October 24, 2021, 02:06:19 am »
 i located the test points under the psu cover,they all read within 100mv of what the service manual states.
Online andy3055
Re: tek 2215
« Reply #34 on: October 24, 2021, 02:24:18 am »
Even though the test points have the specified voltages, check the transistors and make sure they have the correct voltages.
Re: tek 2215
« Reply #35 on: October 24, 2021, 02:42:34 am »
thats the next step,trouble is they are total bastards to get to with the crt in the scope,may have to remove it but that looks a major task in itself.
Re: tek 2215
« Reply #36 on: October 24, 2021, 03:14:28 am »
Wel i have the crt removed,wasnt a big job infact,thing is is it safe to turn the scope on without the crt in it,or is the eht gonna spark all over the place and kill things,or should i just reconnect the eht to the tube and fire it up?.
Re: tek 2215
« Reply #37 on: October 24, 2021, 03:47:40 am »
well while i was in there i thought i would check some caps for esr,there are what look like tantalum caps,see pic by the tip of red probe,is that a tant cap?if so it reads infinity.
Offline David Hess
  • DavidH
Re: tek 2215
« Reply #38 on: October 24, 2021, 04:05:52 am »
That is a polystyrene or possibly polycarbonate plastic film capacitor.  Ignore it.  It reads infinity because it has a low value of capacitance.
Online andy3055
Re: tek 2215
« Reply #39 on: October 24, 2021, 04:18:03 am »
I would follow the diagram instead of just checking random components because it tends to make you deviate from what you are after.
Re: tek 2215
« Reply #40 on: October 24, 2021, 04:42:15 am »
i took it out and measured it,its fine,i have just ordered a solder heat gun to remove the transistors and test them,with it being a double sided board i feel i will lift tracks etc,also need to know if i can power this up with the crt removed,or possibly with just the eht connected?
Offline jonpaul
Re: tek 2215
« Reply #41 on: October 24, 2021, 05:42:49 am »
Bonjour
A bit puzzling to read all of these notes from  m3vuv and similar posts on 2215 on the excellent TekScopes Groups .io,
I can only wonder why the complete and correct version of the manual and schematics is not easily available?
I suggest to follow a logical troubleshooting procedure.
Finally as an active contrib on both EEVblog and groups.io TekScopes, i can highly recommend the TekScopes and very surprized that it seems unresponsive to this thread.
Bon Chance,
Jon
Jean-Paul  the Internet Dinosaur
Re: tek 2215
« Reply #42 on: October 24, 2021, 06:26:00 am »
Hi jon,im supprised by the lack of responce from the tek io groupe,my main issue is running the scope to check transistor base voltages in the vert amp section with the crt removed as its nearly imposible to probe them with the crt in the scope,but im wondering if i power it up without the tube in,will the eht rise to crazy levels and kill something,thats where i am at  at this moment in time,sort of chicken and egg,i have the correct manual,but on a pdf its hard going,i much prefer paper! 73 m3vuv.
Re: tek 2215
« Reply #43 on: October 24, 2021, 03:07:12 pm »
is it safe to power the scope up with the crt removed to take measurments?,as stuck until i get advice on doing this.tia.
The following users thanked this post: andy3055
Offline Ground_Loop
Re: tek 2215
« Reply #44 on: October 24, 2021, 03:41:34 pm »
With no input signal and the input switch set to GND can the trace be positioned in the center of the CRT?
There's no point getting old if you don't have stories.
Re: tek 2215
« Reply #45 on: October 24, 2021, 06:09:50 pm »
FFS cant you guys read my last post!!!!
Offline Ground_Loop
Re: tek 2215
« Reply #46 on: October 25, 2021, 12:28:45 am »
I was just asking to see if you had tried it before taking the CRT out.  Anyway, I doubt anyone is going to tell you it's safe to run the scope with the CRT disconnected and I hope the reason is obvious.  Try it, see what happens.
Offline bdunham7
Re: tek 2215
« Reply #47 on: October 25, 2021, 03:52:26 am »
I've never run one without a CRT in it so I can't be completely sure that nothing will burn up due to no load, but I don't know what it would be.  As for personal safety, there's about -2000V on some of the CRT socket terminals, about +10kV on the red wire that you disconnected from the front of the CRT and a few hundred volts or so on the 4 wires you disconnected from the middle of the CRT.  I'd be super careful not to let any of those short out on anything, especially the horizontal and vertical deflection wires..  Usually I can do everything I need as far as testing from underneath, but if that isn't practical and you want to do it with the CRT out, I wouldn't go probing around a live board.  Connect up with test clips, then power on and be sure to power off and wait a bit before moving on.
Re: tek 2215
« Reply #48 on: October 25, 2021, 05:59:09 am »
Well i hooked up the eht to the crt and moved the whole lot to one side,heres a few readings i took,on q387 base i get 8.8v,it should be 2.6!,r290 wiper measures as follows,fully cw=3.44,fully ccw 3.4v,r190 is fully cw3.4,fully ccw 3.4v,dont know if this helps?
Re: tek 2215
« Reply #49 on: October 25, 2021, 06:01:26 am »
groundloop,with both inputs set to ground and no input the furthest up the screen i can get both traces is about 2 divisions from the bottom of the screen.
