Author Topic: Tek 2235 Vertical Attenuator  (Read 139 times)
Offline jdragoset
« on: October 21, 2019, 09:03:03 pm »
Following removal (intermittent solder joint or contact in channel 1 on higher ranges) instructions, the coupling selector cams seem adhered to the coupling selection levers.
Is this something that would have been repaired with adhesive or is there a release method?
Thanks in advance.
Offline jdragoset
Re: Tek 2235 Vertical Attenuator
« Reply #1 on: October 22, 2019, 12:27:48 pm »
The coupling selector levers snap/click into and out of the coupling selector cams.
