Hi All!! New poster so hope this is the right spot. I recently picked up a used Tek 2246 and it mostly works. I am having issues with some of the buttons not working. Specifically, Down buttons for Mode (A, B XY etc), trigger mode, coupling and source. Top menu button, display clear, AC coupling and Channel 3 select all seem to do nothing. The other channels (1,2 and 4) all seem to work ok.
I am new to owning a scope so I need a little direction. I have not yet removed the cover. Is this even worth an attempt to repair?
Thanks in advance!!
Rob
