Ok, from bottom to top as you have it, and from bottom to top, the transistors are Q2506 to Q2501. Measuring the DC voltage on the square pads, which is the emitter,
Q2501 = 1.5
Q2502 = 1.28
Q2503 = 1.35
Q2504 = .788
Q2505 = .885
Q2506 = 1.34
Now, if you hold the positive lead on the emitter, (square pad), of Q2503, and then press AND HOLD the Channel 1 button, under the vertical mode, you should see the meter drop to .88 vdc.
