I just acquired a tek 2445 that the person I got it from said the fan is not working, opened it up and ther was no fan. I got a refurbished power supply with fan and the scope comes up fine now. The problem I have is when I put a signal on it, I get a trace but the horizontal time base rotary switch doesn't do anything, no change in the time base. Another friend who is a retired electronic engineer said I might try to clean the switch (he did was not able to look at the unit itself just an idea he had). I was wondering if this is the probable cause or if someone has another suggestion. If I need to clean the switch what cleaner do you suggest and where to get it, no radio shack anymore, so thought digikey or mouser something like that. Thanks for any help.
