Author Topic: Yamaha RX-V583 DC Protection  (Read 168 times)
Offline pbarker73Topic starter
« on: December 31, 2024, 02:56:20 pm »
Hi Folks
Long term lurker, first post.
I've got a Yamaha Rx-V583 which goes into protection mode when turned on. Bypassing protection the error is DC PRT: 000. Page 37 of the attached service manual suggests this is an abnormal DC output at the speaker terminal. Following advice from other threads here I've measured the voltage at the emitter resistors. All the channels measure 0V except SBL which measures 0.17V, so I'm guessing that this is the culprit. My question is, is it likely to be the output transistors - is it worth pulling the main board and removing them to check them? If not what would be a good next step?
Edit - can't attach the service manual it's too big. https://drive.google.com/file/d/1r3LtY7z8kruw282SWtCtpTQzt4xsjmVl/view?usp=sharing.
Thanks
« Last Edit: December 31, 2024, 03:02:24 pm by pbarker73 »
Online Swake
Re: Yamaha RX-V583 DC Protection
« Reply #1 on: January 01, 2025, 03:28:06 pm »
Might be, or another one, or even a passive component. Start with checking all the Q's and D's in in that area. Page 130 Zone 4-5 / C-D-E
And also Q2005 on page 132.
DC PRT: 000 -> the '000' part indicates that the voltage was 0 Volt. That is somewhat strange. You could also have an issue with the power supply of that SBL amplifier.
When it fits stop using the hammer
