I have a Tektronix 2465 that had this same issue. With my scope both the trace and readouts would start to shimmer and then shift so far to the left that everything would be completely off screen. Pressing the beam find button would restore it for a while but would happen again a few moments later. But since then I have used this scope very infrequently, and now the problem has seemed to have fixed itself. I have used this same scope to adjust the OCXO's in my T&M gear and it has been working fine, for now. There are however some light artifacts that are present during the first few minutes of operation but go away after that. My guess is it's either the U800 or some intermittent issue in the power supply.
