Hello,
New to this forum and I'm not much good at electronics, but I try ;-)
I'm trying to bring a recently failed VFD back to life, and pulled out the TEK 465 to poke around on the control boards. I've replaced a pair of diodes and a small cap, but have yet to discover the failure. Typical....
What I did discover is the DM 44 section on the TEK465 is on the blink. It has had problems in the past that have been made right by re-seating the A_D converter IC.
A pass through the service pages for the DM44 points to the A-D converter area. The IC is a LD111A . I have not been able to locate 1 piece to replace this suspect device.
On line brokers seem to go for higher part qty.
Also, It appears that the LD111ACJ is the present day replacement. TRUE? a direct interchange?
Suggestions on source or replacement part?
TIA
Cal
