Hi all. Just picked up a partly working 465 that after a full switch clean mostly works.
When I say mostly the XY mode produces an extremely bright moving beam somewhere off screen. I can not move it to the crt screen and would not dare as I'm sure it would burt the screen. Also even at minimum intensity it is too bright. I know this as the beam can be seen reflecting off the side of the CRT.
Is this a knows fault? Any pointers?
Thank you in advance.
Those are two independent faults.
Always start by checking the various power supply rails for voltage and ripple.
If you apply a large input signal, does the trace partially come onto the screen. If so, the problem lies in the amplifiers, possibly correctable by following the service manual maintenance procedures. If not, additionally suspect the connections to the tube or tube itself.
The intensity problem indicates a problem in the blanking circuits. Quite possibly there is a failure in the high voltage diodes or capacitors in that translate the 75-150V blanking waveform up to -2500V. I've also seen a detached grid connection
inside the CRT, which would be game over.
Caution: in extreme cases an excessive grid current can damage the mesh or CRT envelope.
