Hi guys
I have a Tek 465M scope. Until yesterday worked OK. but today in the morning, after working good some minutes, suddenly, just the screen turn off. Trigger and channels still work (signals are triggering in the same point). The last I was doing was using the delayed timebase mixed with normal, using the intensity option.
these the last images I have of it, prior to death (I see it working properly, but I can be wrong). (Don't worry about the quasi-sine waveform, is correct, is being formed from PWM)
in this, mixed timebase(I see it working properly, but I can be wrong) (the quasi-sine waveform is correct, is being formed from PWM)
Something I noted: yesterday I smell "old capacitor". This guy always smell like that because was stored in a place with tons of old equipment, with old capacitors. Is possible that I mistaken this smell with a cap failure. No smoky smell, no strange behaviour of buttons, no whines, nor buzzes, no hot spots. Anything apparently works Except Screen. The last time I opened it was to fix the horizontal position shaft, anything looked ok and worked ok 3 years from that.
I suspect that one of the high voltage CRT power sources "died".
Thanks for any help :-
