Sorry to resurrect, but I got a 468 recently, and it has a problem
Well it had a couple, I fixed them, this is the one that's left...
After startup when cold, the screen will sometimes go crazy - usually gets bright, traces going all over the place, sometimes it turns into a dot, then brightness beings to fade. The indicators will dim, the fan will change pitch, and basically the scope won't work, digital or analog. But a quick tap to the side of the scope after it has its fit generally brings it back, and it will continue working until it is turned off and cools down again.
I've been trying to find out what might be loose or otherwise causing this by tapping on various parts of the board when on while the problem manifests, making sure all contacts are good, etc. but just can't seem to fix it. No knobs or buttons bring it back or change it. When it comes back, everything functions 100%. I've tried tapping on components and on the boards but that usually won't bring it back, tapping on the side will though. Don't have to tap very hard either. All obvious connections seem to be OK (have tried unplugging/cleaning/replugging everything I can get to). All socketed components seem to be OK. Basically I'm at a loss now. Hard to troubleshoot because even if I do not tap the chassis, it will fix itself in a couple minutes.
Sometimes if the problem doesn't occur I can induce it by pushing on the left side of the front panel.
Any ideas on what this is or where to even look? Should I ask TekScopes?
Also the scope is camera shy, it would do it if the camera wasn't on but would refuse when being recorded. I eventually got it:
