Author Topic: Tek Scope Probe Repair  (Read 2121 times)
Offline RerouterTopic starter
« on: March 27, 2017, 11:13:22 am »
First and foremost, I'm mainly doing this as a learning exercise, i already have enough working probes to handle my day to day
One of my older fixed X10 probes has a partial breakage at just past the stress relief, about half the sheilding is still intact, and the probe itself still functions
I am wondering if there is any better way to fix it that putting 4:1 heatshrink over the probe and down the wire?
e.g. is there any kind of inline splice crimp for this kind of thing, or a way to reverse out the original crimp and loose 2 inches
Online PA0PBZ
Re: Tek Scope Probe Repair
« Reply #1 on: March 27, 2017, 11:27:44 am »
The cable is probably part of the divider network so cutting off a piece is likely not a good idea. What I would try is peeling a bit of the plastic from both ends of the break, get some shielding from another cable to put over the gap, then heat shrink and be done.
« Reply #2 on: March 28, 2017, 10:06:43 am »
Thanks for the advise, it actually makes a very sturdy repair.
I trimmed 5mm back on either end, then tightly wound copper braid around it and i am just waiting on more stock of 12mm 4:1 heatshrink to seal it over, but so far it maintains most of its original flex, which considering it failed right next to the stress relief is needed,
