Dear all,
I have been struggling to fix a Tek 577 curve tracer for some time and I have posted other question related to this project but I decided to create a new topic with this question since it seems to be very specific.
After calibrating the 177, I tried to continue with the 577 calibration procedure, but it is not possible to adjust the trimpots.
So I decided to try the performance check to try to identify which section(s) of the circuit are defective.
It turned out the I found that there were problems in both the vertical AND horizontal gain sections.
The "workable" area on the display is a square of approx. +-4div horiz and vertical.
So I moved to diagram 7 (Vertical & Horiz Output Ampl ) for serial numbers below B082440, which is my case.
First I checked the +200V, which seems to be a little high 220V but since there is no adjustment I guess it is not the cause of the problem
My next step was to measure the voltage between +VERT and -VERT as well as +HORIZ and - HORIZ.
The manual says the gain of both vertical and horizontal sections should be 0.5V/div.
However what I am observing is that the gain is correct from +1.5V to -1.5 V for the vertical and highly off for the horizonTAL
Here are my measurements
Vertical section
voltage(V) deflection (div)
2.0 to 5.0 3.1
1.5 3.0
1.0 2.0
0.5 1.0
0 center
-0.5 -1.0
-1.0 -2.0
-1.5 -3.0
-2.0 -3.5
-2.0 to -4.0 -3.8
Horizontal section
2.5 to 4.5 3.9
2.0 3.4
1.5 2.5
1.0 1.9
0.5 1.1
0 + 0.2
-0.5 -0.5
-1.0 -1.3
-1.5 -2.1
-2.0 to -5.6 -2.8
Is it possible that all 4 output transistors (Q1104, Q1114, Q1124 and Q1134) have failed?
Any ideas to explain this non linear behavior of BOTH sections?
I have attached the schematics of this section for to make things easier for anyone who would like to help
Thank you very much in advance,
Roger
Vertical & Horizontal Amplifier.pdf (228.77 kB - downloaded 67 times.)
