New member here
Just been asked by a friend to repair one of these. Sounds and light work but not the motor.
After checking all the obvious things (battery, wiring, switches, etc.) I had a look at the PCB. No signs of overheating but I found the relay not operating because Q2 was open circuit.
Original was an MPS8050. NPN 1.5 Amp
Nearest I had was a BC338 0.8Amp, but with reversed pinout, EBC instead of CBE.
Fitted that and now the motor runs (but the switch on the top of the cab seems a little intermittent)
Just hope the BC338 survives, but it's only switching the relay. I didn't measure the relay coil but would expect about 100mA
