Hi Guys, bit of an unusual one, anyone into R/C models? I am repairing a servo as in the title, it just doesn't work, dead. I took the pcb out and it is double sided with a 20 pin SMD chip on the top with various resistors and caps, all of which I have checked, and the underneath of the board has the four motor drive FET's ttwo N chan two P chan., a SMD cap and a component which has fallen apart! and I have no idea what it is.
It's about three mm squar, white on the top, it appears to have three solder points on two opposite sides, they are not pins, they are like pads on the side, when I removed what was left of it from the pcb with my hot air station I find that the three connections on the side go all the way across underneath so they are sort of wrap around pads, and in fact it has only three connections, and sure enough the pcb track is three strips under it.
I just cannot identify it, it has a white top with 20.00 written on it.
I have just been examining the component under a microscope, it looks like a licorice allsort, three layers, brown at the bottom then black then white. on top, Under the 20.00 it has T M3
Anyone any idea of what it may be, or at least what the package is, or better still has anyone got a circuit diagram for the servo please?
