Hi folks,
I am working on the step amplifier of this instrument and I found a very strange behavior of this switch (S404).
This is one of those cam switches used in many Tek instruments
The voltage set part of the switch is showing a resistance much different from the one expected ( using diag 4 as reference).
I removed the aluminum cover of this switch and inspected the gold fingers.
All fingers are there and move as the switch is rotated.
I have sprayed Deoxit gold on the contacts (fingers) and gently slided a sheet of paper when each finger was closed in an attempt to remove any dirt.
Then I measured the resistance between pin 6 of U360 (signal input) and pin 3 of U380 (signal output of the resistor divider) and compared with the expected value.
Note ( measurements taken with U380 pulled out)
The differences vary between 30% and 1/4 of the expected value.
I could not think of an explanation to such behavior.
Here are the values I have measured as well as the expected values:
Knob Volt reading(V) measured resistance expected value
2 1.367 1.505
1 2.517 3.01
.5 4.317 6.02
.2 7.61 15.05
.1 10.18 30.1
.05 12.26 60.2
I am attaching the reference diagram for reference
The measurements in question are related to the Voltage Set Resistors, on the top left part of the diagram.
Any ideas?
