i have repair two 7904 PSU. Both is failed with odd reason.
One runs only up to 170V Input (by 230V setting), then fuse blow. One 940µF of two series is shorted.
other PSU run with two simple plugin with sometime starting issues. Four plugin, it starts sometime , if PSU is warmed up. It make noise "SUMMMM ! SUUMMMM! ", not ticking !
Reason: two power transistor in primary side is semi-broken (to much less current gain by higher current, less than 4 ßeta ), if transistor is hot, it hat gain of "a bit over 4" --> stable oscillation.
Transistor swapped , then it run stable. I have replace him with 2N6678.
Greetings
matt
