Hey guys,,
i am eager to know if you guyz were able to start the DPO 7104 ?
Mine is down with no OS.... and no recovery media.
gone through the thread again and again.. followed the instruction but no luck. The TekScope can't detect the model.
Hi, ok, it looks like your system is looking for some drivers first of all. So we'll first try to get some of them in, as it'll make the system more usable.
I've found a driver for the TUSB33410, which seems to be a USB to Serial Controller. So try installing this.
https://www.dell.com/support/home/en-uk/drivers/driversdetails?driverid=r286478As for the others, I'll need some information from you, to help track down drivers which may work.
So in the device manager, I'll need your to right click each item, go into Properties, a new properties window should open, go into the Details tab at the top. Then in the drop-down box, choose Hardware IDs, and then in the box underneath, it should list a few PCI/VEN numbers. I need the VEN number, DEV number, CC SUBSYS &REV (if present). Do that for each device.
The video driver, I think it might be this -
https://www.amd.com/en/support/graphics/legacy-graphics/ati-radeon-ve-series/ati-radeon-veI've did some digging, and this seems to be a cut down Radeon 7000 driver, but we may still need to mod it to work. Don't run through the installer, instead manually install the driver, so it doesn't put in the catalyst crap.
https://itstillworks.com/replace-missing-windows-xp-drivers-6881088.htmlI am assuming here that you have some XP knowledge, and know how to install drivers??
Anyway, if you get back to me with the PCI/VEN & DEV numbers, i'll try and track down drivers which should work.
L.
