My FG504 is sick.
When I turn the mainframe on, the signal is there for about a second and then disappears.
Failure then manifests itself in one of two ways :
EITHER - no volts at all on power rail test points
OR - +25 and +15 is present, -25 and -15 is not present.
DCR check on the rails does not indicate short to ground, and have checked the obvious tants that I can see for shorts. Can't find any.
Very odd that there is a signal for a second or so on power up and then it disappears.
Any ideas where I should start?
PS - No, I don't have extenders, however I can slide the side off my TM5006 which allows me to access quite a lot in situ.
