Hello,
Attached picture of 4 probes I've purchased lately where my questions are about (1) how to remove the grey plastic hosting the hybrid (2) where to find replacement of this grey plastic and (3) how to remove the transparent tip plastic or grey metal housing.
Two probes as you can see have partial grey plastic broken
Another probe seems to have a bad contact inside its metal tip, sometimes it works good and sometimes no signal where I obtain the signal by pushing laterally the end tip
More generally, does these tektronix P6243 are reliable, good in performance and worth repair ?
I notice when using them the plastic grey housing will heat a bit, I guess the internal hybrids got hot hence will deteriorate or crack the plastic. No idea if this is normal, alarming and how to fix.
Thank you in advance, Albert
