Refering to the picture posted in the OP, the three latching relays perform these functions:
The blue relay on bottom left switches AC/DC coupling.
The blue relay on bottom right switches 50 Ohm to ground, on output of above relay.
The white relay selects attenuator network for [1,2,5,10,20 mV/div] or the networks for [100,200,500 mv/div] [1,2,5,10 V/div]
The [brackets] represent 3 different signal paths into the custom amplifier / differential adc driver.
The dark green areas are laser trimmed resistors, e.g. the input 50 Ohm terminator resistor is adjacent to the input ac coupling cap (at the very bottom of the module). I have a rough block diagram somewhere, I'll have a look for it.
