Author Topic: Tek TDS360 floppy drive and LCD replacement.  (Read 763 times)
Offline philwong5176Topic starter
« on: September 11, 2021, 03:18:28 pm »
Hello:
I have 2 issues with my Tek TDS360: the floppy drive is dying, and the CRT is getting very dim. I would like to replace the floppy drive with a SSD or an SD card cage, and find a suitable LCD to replace the CRT.
Would veterans of these upgrades share their experience here? I am aware the final upgrade cost would exceed the current value of this scope.
Thanks.
Offline pcwrangler
Re: Tek TDS360 floppy drive and LCD replacement.
« Reply #1 on: September 12, 2021, 04:07:32 am »
What is the floppy drive doing? Have you tried cleaning it?
Offline james_s
« Reply #2 on: September 12, 2021, 05:07:39 am »
Are you sure it's the CRT itself and not a fault with the monitor electronics? Does it get blurry if you turn up the brightness pot inside? It's a standard VGA resolution monitor so it shouldn't be hard to connect a modern LCD if you can find one that fits physically.
« Reply #3 on: September 13, 2021, 04:52:37 pm »
The floppy drive keeps spinning once a disk is inserted, and does not red or write from/to the disk.
Offline pnv57
« Reply #4 on: September 14, 2021, 11:47:44 pm »
Are you sure that it is formatted correctly? Is the spinning intermittent or constant? I had a similar issue on my tekmate when I tried 1.44M formatted 3.5" floppies in it, when it needs 720K format.
