Author Topic: Tek TDS7404 tips about log welcome  (Read 5425 times)
Offline hazelnutsky
Re: Tek TDS7404 tips about log welcome
« Reply #25 on: June 27, 2024, 12:15:01 pm »
Hello,
I just bought a TDS7404 and it appears I have no trigger on channels 1 and 2 and SPC Fails. So I guess am looking for a trigger chip 156-8278-00.  Where can I get one from ? I am hoping some kindly soul on here will sell me one .
KR, Hazel
Offline squadchannel
  • Country: jp
  • deepl translate user
« Reply #26 on: June 27, 2024, 01:57:52 pm »
trigger chip is Unobtainium. |O The owner of a non-triggering TDS74xx is always on the road looking for a trigger chip.  :o :o :o
Offline coromonadalix
« Reply #27 on: June 27, 2024, 02:22:37 pm »
@hazelnutsky
yep  have to find them on any tek pcb you may find ....  6k series have them ...
but i would say     check the VxWork  log  while booting  etc ... to be sure  it/they  don't respond to the hardware scan ... , you have an 10 pin idc console port you need to connect to
and theses 7k series may too suffer some eeprom corruption too on acq board,  who may or will spit some errors in SPC tests,  you have to be sure all tests have been done and verified too
and the famous nvram battery who dies, it depends on witch chip version you have, and if it died   you lost some configs and need to put them back  if tekscope crash while starting,   if not   you may be lucky ...
you have an huge tds7k serie thread here
https://www.eevblog.com/forum/testgear/tek-csa7404-repair-project/
and another thread
https://www.eevblog.com/forum/repair/tek-tds7404-calibration-debugging/
pls  dont double post, if you are tempted, you'll not be loved
« Last Edit: June 27, 2024, 02:33:12 pm by coromonadalix »
Offline hazelnutsky
« Reply #28 on: June 27, 2024, 04:26:45 pm »
I guess I _could_ start a new thread for this.  I built an RS232 interface, and now I can see this , which I think means the NVRAM is dead?
      ]]]]]]]]]]]  ]]]]     ]]]]]]]]]]       ]]              ]]]]         (R)
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]       Development System
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]       VxWorks version 5.3.1
 ]]]]]]]]]]]]]]]]]]]]]]]]]]       KERNEL: WIND version 2.5
 ]]]]]]]]]]]]]]]]]]]]]]]]]       Copyright Wind River Systems, Inc., 1984-1997
                               CPU: Tektronix HPP - PowerPC 740.  Processor #0.
                              Memory Size: 0x2000000.  BSP version 1.0.8.0 .
                             WDB: Ready.
tcsTableUnpack: checksum failed on buffer
tcsTableLoadFromNVRAM: tcsTableUnpack failed
KERNEL: THERMAL CONTROL INITIATED
" [ Attachment Invalid Or Does Not Exist ]
« Reply #29 on: June 27, 2024, 09:52:25 pm »
change the battery if possible  and in the big thread you have  a 7404 config i had to rebuild ...
« Reply #30 on: June 28, 2024, 11:09:53 am »
tds7404 i restarted, dead battery, eeprom corruption on acq board (gave spc errors)  now all is fine no errors. ram upgrade and new hdd
[VxWorks Boot]: ?
 ?                     - print this list
 @                     - boot (load and go)
 p                     - print boot params
 c                     - change boot params
 l                     - load boot file
 g adrs                - go to adrs
 d adrs[,n]            - display memory
 m adrs                - modify memory
 f adrs, nbytes, value - fill memory
 t adrs, adrs, nbytes  - copy memory
 e                     - print fatal exception
 n netif               - print network interface device address
 N                     - set ethernet address
type c  and enter,  you should begin to do the settings like this :  and your entries should be after .....
see in bold, at first you'll see what they are by default,  you put yours ....
  If you do a mistake  you can go back  or redo the settings loop ...
[VxWorks Boot]: c
'.' = clear field;  '-' = go to previous field;  ^D = quit
boot device          : sm                                           sm
processor number     : 0                                         0
host name            : host                                         host
file name            : c:\vxBoot\vxWorks.st                 c:\vxBoot\vxWorks.st
inet on ethernet (e) : 192.168.0.2:ffffff00               192.168.0.2:ffffff00
inet on backplane (b): 192.168.0.2:ffffff00              192.168.0.2:ffffff00
host inet (h)        : 192.168.0.1                              192.168.0.1
gateway inet (g)     : 192.168.0.2                           192.168.0.2
user (u)             : anonymous                                 anonymous
ftp password (pw) (blank = use rsh): anonymous          anonymous
flags (f)            : 0x1000                                        0x1000          some had to put 0x1008  in my case it did not help
target name (tn)     : target                                     tds7000     this one should be tds7000, otherwise tekscope will not save settings
startup script (s)   : c:\vxBoot\dio_rst.vsh               c:\vxboot\topscript.hw
other (o) :                                       this one play tricks   had to put 0x0 or 0x0000  tekscope had some problems, some have put 0x1000
« Last Edit: June 28, 2024, 11:19:02 am by coromonadalix »
Offline hazelnutsky
« Reply #31 on: July 01, 2024, 04:41:52 pm »
OK, found the BIG thread about this, and moving my comments there.
https://www.eevblog.com/forum/testgear/tek-csa7404-repair-project/850/
The following users thanked this post: coromonadalix
Offline darkroom
« Reply #32 on: August 29, 2024, 02:51:11 pm »
I am sorry if this is posted elsewhere, but I just couldn't find it.  Where can I find into on this RS-232 cable, and what it hooks to in the analyzer?  What is the voltage?  TX, RX, GND only?
Any help appreciated!
Austin
- Update Found it here:
https://github.com/exit-failure/tds7000/blob/main/NVRAM/README.md
I think this is what I'm looking for.
« Last Edit: August 29, 2024, 02:54:55 pm by darkroom »
« Reply #33 on: August 29, 2024, 03:48:10 pm »
yep that's the info's i used, and i had  the super cap  thingy on top,  i put an 2032 cell in a socket  near the ic and soldered the wires on it
sadly all the infos get diluted, and hard to come back   ...
